bucketep91 Posted June 25, 2009 Posted June 25, 2009 take out the dial surround and cluster to get to the dials, unscrew the little screws to release the old dials (you can leave them in if you want and put the new ones on top) put in new dials and screw them back in. now you just have to power them, the little box that comes with them has 2 wires 1 is the power the other is earth, i connected them to the back of the rear fog light switch, so when i turn on my lights the dials come on. the other wires on the box connect up to the wires on the dials, you will have about 6 of the wires on the box but you only need 3. that should be it just put everything back together carfully not to stretch or bend the wires coming from the dials as they are very cheaply made and sensitive( 1 of mines are broken and it pisses me off) hope this helps Quote
