right guys is this the right td05/td04 turbo you need to fit on the starlets its off an impreza as most off them are or is there another one???can you post some pics up off the exact turbo everyone uses if it is different?????
Guest Enzo
im not totaly sure but if its off a scooby then it should be the right td05 to fit onto the starlet
obviusly you will neeed the custom manifold etc
will be alot more laggyier then the tdo4 but more able to produce power at a lower psi,
if ytour going for big power get this badboy,
if not stick with a tdo4 mate,
thats my two pence worth
cheers guys but any ideas where i can get manifold for it????or where can i go to get somethin custom made needs to be local to me though(gatwick area) fuelling is ok my car is gonna go to gtart to have it all setup and am gonna only run 1bar to play it safe until i put forged in it then go bit more B):D !!!!!!!!!!!!!
