BAZ2CRAZY Posted July 17, 2009 Posted July 17, 2009 Im now sick of the standard n/a seats, i have always wanted a bride seat and if i was to buy one (second hand) and it was to come with say a 200sx rail how would i go about mounting it to.... my starlet?Thanks in advanceMitch Quote
Dan_SV Posted July 17, 2009 Posted July 17, 2009 right, i have recently fitted a bride seat to my Glanza and the easiest way that we found was to create a subframe from scratch. it came with no rails so you maybe able to modify those to fit.in mine we originally planned to use the standard glanza frames to mount the seat on but this was nearly impossible, instead we cut some small box steel to make a frame on the bottom of the seat, then we fitted this to some aluminium lengths that we mounted to the bottom of the car. this was by far the easiest way that we found.hope this helps you.(i have some pics of the build up that i will try and get posted as well) Quote
BAZ2CRAZY Posted July 17, 2009 Author Posted July 17, 2009 right, i have recently fitted a bride seat to my Glanza and the easiest way that we found was to create a subframe from scratch. it came with no rails so you maybe able to modify those to fit.in mine we originally planned to use the standard glanza frames to mount the seat on but this was nearly impossible, instead we cut some small box steel to make a frame on the bottom of the seat, then we fitted this to some aluminium lengths that we mounted to the bottom of the car. this was by far the easiest way that we found.hope this helps you.(i have some pics of the build up that i will try and get posted as well)Cheers mate, il have a look at your threadMitch Quote
BAZ2CRAZY Posted July 17, 2009 Author Posted July 17, 2009 sorry thought it said somthing else, yeh dude, post them pics up here!Mitch Quote
rob_bower Posted July 17, 2009 Posted July 17, 2009 its all down to the runners really and how they line up to the standard mounting points!! when i fitted the fto seats in to the sr all we did was remove the feet of the fto rails and make new feet from some steel plate weld them on!! Quote
Dan_SV Posted July 17, 2009 Posted July 17, 2009 by the way dude, forgot to mention that my seat is non-moveable. it is a recliner but you can't move it forwards and backwards.this wasn't a problem for me because i am pretty tall and have the seat as far back as possible anyway!!! Quote
Liam_D Posted July 17, 2009 Posted July 17, 2009 Or you could just by Bride Subframes for the EP91 like i have. If funds allow of course!! Quote
BAZ2CRAZY Posted July 20, 2009 Author Posted July 20, 2009 Cheers lads, so theres no 'universal' subframe option?Mitch Quote
Liam_D Posted July 20, 2009 Posted July 20, 2009 Dont believe so mate, its either Bride frames or Custom ones. Quote
