minxy Posted July 27, 2009 Posted July 27, 2009 Hi, does anybody know if ep82 GT drivehshafts will fit a Glanza - I've seen people use the gt gearbox in a glanza so I'm guessing the shafts are the same too?! Can anyone confirm this? Thankyous!Karen Quote
Kennedy Posted July 28, 2009 Posted July 28, 2009 Think aslong as the spline count is the same you should be ok..although there are two different spline counts. Quote
WallaceGlanza Posted July 28, 2009 Posted July 28, 2009 Think aslong as the spline count is the same you should be ok..although there are two different spline counts.Correct, also the drivers side driveshaft is different between the lsd and non lsd gearbox models. Quote
