Does anyone know if there are any engine parts from the 4age engines(16v) that could fit to a starlet engine?
I have shit loads of 4age engine parts so i was just curious. I've even got a set of toda cams! (i know these wont fit though).
i know i just pm'd you but i think I've read somewhere of someone using a 4age throttlebody on a 4efe think it was modified though, mite have been in a corolla aswel, be the same either way. you shud be able to use the injectors but a gt/glanzas will be bigger anyway
and do you have a 4age smallport crank laying around? and any performance parts? all of which are for sale
  • 5 years later...
You can use valve springs, retainers, valve guides, valve stem seals from the 4AGE 16v, their all the same. But DO check the spring base pressure as the head might need to be milled or have a valve shim.
