the only bolt i can see that came off left a small hole that seems stupid for a fill point
if anyone could take a picture it would be helpful but also any info would be good. thanks
Russell
i wanted to change mine i think its a 25mm nut? am i right? i tried with a spanner to drain it but the spanner was to big, other parts of the gearbox are too close to the side.
need to get a socket for it because only got a 24mm and 26mm :harhar: lol
the drain plug is on the bottom and pretty easy to get to. yeh i think its either 24 or 25 i can check tomorrow and ill put it up here and see how filling up goes.
Russell
The drain is at the bottom.
The fill/level is a 24mm slimline nut on the front of the box, roughly half way up and in the middle.
You can fill through this and wait till it starts to come out this is the correct level.
Edit; here you go found you a picture.
