when i drive along i sometimes hear a knocking and wen i brake it does it sometimes i think it might be the drive shafts but not to sure :S
it dont do it all the time but wen goin slow you can feel it and wen rolling and brake you can hear it can some1 help me ??????
like he says ^
i had same kinda problem, turned out to be wishbone, is it a specfic area it comes from? i.e. left or right or is it from directly under the hood?
again as above id do that
if it was driveshafts it would be speed dependant or would knock like hell in full lock
but just to be sure check the cv boots.if one of those isnt on properly dirt and crap could of got into the driveshaft bearing and buggered it
ive checked the wishbones and there no play in the bushes or ball joint and ive took the drive shaft off and i was just wondering what to look for to see if it that which is making the noise thanks.
