I've had an annoying boost leak for the last couple of days now so I've just spent a while there going round all the pipes and ended up lifting the i/c a wee bit higher and re joining everything tighter, but cut a long story short: you those little clips on the front splitter for attaching it to the bumper? well 1 of them was digging into my i/c core and the fins are bent right in could this be causing my boost leak? if it is that how would i fix it?
Aryt man,
If that is the problem my stepdad has his own company which specializes In automotive radiators intercooler and oil cooler repair and supply,
He does pressure testing in house, can repair leaks, and is cheap,
He is just outside Dundee which isn't that far from you I don't think,
I could get you a contact number if you are interested bud?
Gary
