Tha Dragon Posted August 11, 2009 Posted August 11, 2009 Hi there Guy's,Yesterday i installed my aftermarket exhaust mani & Downpipe and ported the wastgate a bit, i bought a overhaul gasket Kit,change the seals and almost everthing, before the installation i already had problem with boosting cause when i stepped on the gas like ful trottle it boosted until 0.66bar and i had a broken gasket(the one that goes to the blackpipe to the intercooler) and when the boost lights came on all 3 went on but after a few seconds you'll see my boost dropping, but yesterday i fixed it and know it will only boost to 0.46bar and only to boost lights go on.Could 1 of you guy's give me some advice what the problem could be?I'm busy with a 200hp.i got a FPR liquid filledAftermarket Exhaust Manifold & DownpipeAftermarket Racing AirfilterTurbonetics Manual Boost ControllerStock TurboStock CatbackAbout to install HKS FCDAgain Could 1 of you guy's give me some advice what the problem could be?Thanks in advanceTha Dragon Quote
Tha Dragon Posted August 11, 2009 Author Posted August 11, 2009 Do you have an uprated actuator?No uprated original actuator. Quote
Tha Dragon Posted August 11, 2009 Author Posted August 11, 2009 No uprated original actuator.Isn't there no one else that could help me with my problem cause i really want to push it of a pier or something right now!!!!Thanks. Quote
Tha Dragon Posted August 11, 2009 Author Posted August 11, 2009 so?.........its not holding boost?No it's not holding boost it's really freaking me out cause i'm upgrading but my car is downgrading with all it's upgrades. Quote
Guest Enzo Posted August 11, 2009 Posted August 11, 2009 it sounds like your standard actuater possebly, the standard ones are known to be weakhow much boost are you running? does the boost drop off?first of all i would check that you have no air leaks, Quote
scot-ish Posted August 12, 2009 Posted August 12, 2009 i'd look at the standard actuator, all them new parts, get yerself a hks adjustable actuatoroh, and how come i never seen no starlets when i was on curacao lol Quote
Tha Dragon Posted August 12, 2009 Author Posted August 12, 2009 i'd look at the standard actuator, all them new parts, get yerself a hks adjustable actuatoroh, and how come i never seen no starlets when i was on curacao lolYou were looking for them at the wrong place at the wrong time,always at night always in salinja in the weekends or threw the week.I was about to order 1 but how much effect does that have on my stock turbo? cause i was about to order a bigger 1?Thanks Quote
AlexGTAdv Posted August 12, 2009 Posted August 12, 2009 I would definatly say get an uprated actuator. Whats happening is as the revs build the actuator cant hold the wastegate so its opening and that is why you are loosing boost. Uprated actuator will sort this for sure! Quote
Tha Dragon Posted August 12, 2009 Author Posted August 12, 2009 I would definatly say get an uprated actuator. Whats happening is as the revs build the actuator cant hold the wastegate so its opening and that is why you are loosing boost. Uprated actuator will sort this for sure!Ok,thanks for the info.I'm going to check out if i have a leak in some of my hoses this weekend to know if that's the problem if not then i'll order a uprated actuator.thanks for the advice guy's Quote
scot-ish Posted August 12, 2009 Posted August 12, 2009 You were looking for them at the wrong place at the wrong time,always at night always in salinja in the weekends or threw the week.I was about to order 1 but how much effect does that have on my stock turbo? cause i was about to order a bigger 1?Thanksi was in willemstad, and around there, up at bullenbay(bullenbaai i think it is) just for a few days when my ship came in there,i'd say get the hks actuator, there only £100, and would be the most likely cause as described there Quote
AlexGTAdv Posted August 13, 2009 Posted August 13, 2009 This may helphttp://www.toyotagtturbo.com/forums/showthread.php?t=51376 Quote
Tha Dragon Posted August 29, 2009 Author Posted August 29, 2009 Thanks guy's thanks for the info..You guy's Rock!!!!! Quote
Tha Dragon Posted November 15, 2010 Author Posted November 15, 2010 Finally got my HKS Actuator have it installed,On low boost 1st and 2nd will boost to 0.5Bar and the other gears between 0.7 to 0.9 ish.Hi Boost 1st and 2nd between 0.5 and 0.7 and the other gears 0.9 just before fuel cut.When i tried redistrict it it will pass 1.0 and hit fuel cut.I ordered a HKS FCD installed it next to the ECU but my car kept going Fuel Cut is there anyone that could give some advice on where to install it for better result.Setup:i got a FPR liquid filledAftermarket Exhaust Manifold & DownpipeAftermarket Racing AirfilterTurbonetics Manual Boost ControllerStock TurboStock CatbackSupra Fuel PumpMSD CoilTRD Sparkplug CablesExedy Stage 1 Racing ClutchHKS ActuatorSome advice huy's please.Thanks in advanceTha Dragon Quote
Wantaglanz Posted November 15, 2010 Posted November 15, 2010 sounds like the FCD isnt installed correctly Quote
adz_sportif_turbo Posted November 16, 2010 Posted November 16, 2010 theres a how to somewhere maybe its on tgtt,,,when i looked at it it shown it being installed near the map sensor (i think it was a jam fcd but they work off the same principle). have you got your fpr set up?? i wouldnt run over fuel cut otherwise. take out the hi/lo boost setting and set up your levels to 12 psi just to be safe until u can set up your fuelling. Quote
Qglanz Posted November 16, 2010 Posted November 16, 2010 Jimmy look me up and i'll let you see how mine is installed how you didn't cut the wrong wires ! Quote
Tha Dragon Posted November 16, 2010 Author Posted November 16, 2010 Qglanz,Ok i'll let you know, i'll be working on my car this weekend so i'll give you a ring and let you know tha station.thanks guy'sTha Dragon Quote
Tha Dragon Posted November 17, 2010 Author Posted November 17, 2010 Tried it yesterday again, installed the FCD near the ECU, check engine light goes on test drive boosting like s.....,when i did a diagnostic test it gave me Error code 31, when i took the FCD of check engine light went of and boosted again.What am i doing wrong guy's, i'm going to install it for the last time this saturday where the Map Sensor is located and if it doesn't work there i'll throw the damn thing away and go save for an EMB.Thanks in advance Quote
