one of my ball joints was leeking slightly so i thought id replace both of them before they get worse, I've managed to undo all three nuts on the wishbone connecting to the ball joint, and I've got the top nut off that holds it in place, but the fucking thing just wont come out, I've been hammering it and all sorts for ages and no budge!!! and now i think i may have fucked up my cv joint because when i move the hub around you can hear the splines on the cv joint rubbing against something....
Is there an easy way of getting ball joints out at all? and do you think i should now replace the CV joint or just take it off and check it over??
im seriously going to hack the thing to pieces shortly if it doesnt come out....
any help would be much appreciated...
cheers guys
get a balljoint splitter, its basically a really beefy 2-pronged fork, smash that between the ball, and keep hammering, and it should eventually come off, worked for me! :thumbsup:
I just drove a big fat screwdriver down the centre, let it release the peg, as for your c.v. joint, you may have just pushed the c.v joint too far onto the shaft, give it a pull and the spring clip should lock into place again.
Damien
