jim808 Posted August 26, 2009 Share Posted August 26, 2009 ok need some help here really starting to lose interest in this carMy first gearbox lost 2nd so got another from breakers, my mate fitted this and i noticed a slight noise when sitting still with clutch out ( went away when clutch pushed in). This noise got louder over nxt 2 weeks. I thought it might of been the thrush bearing even though there was a new one fitted so had a bit of an inspection and seen that the box was leaking oil and was nearly dry . So swapped the box for another one and bought another thrush bearing just incase. i fitted the box, filled with oil, turned the key, and still i hear this noise. its not just as loud. Also when driving, when i start to pull away in 1st i sometimes feel through pedal and hear a pretty loud grinding noise. its fine once driving.Can someone help me outI can still only think 'thrush bearing' is there a certain way it has to be fitted????Thanks Jimbob Quote Link to post Share on other sites
Glanza_Ragger Posted August 29, 2009 Share Posted August 29, 2009 Normally, when theres a grinding / whirring noise with the clutch up, it means the thrust release bearings running dry and had it.thats usually why the noise goes away when you put the clutch down.If you follow my guide on how to replace a clutch , its in the how to section , then you should be fine.id assume the thrust bearings being a prick. did you grease it up? and check the release fork isnt damaged? Quote Link to post Share on other sites
RobSR Posted August 30, 2009 Share Posted August 30, 2009 If you've replaced the bearing a few times and it's still doing it.. It's probs the clutch. My bet is the centre section is cracked/one of the springs has snapped etc.. Quote Link to post Share on other sites
AlexGTAdv Posted August 31, 2009 Share Posted August 31, 2009 Seconded, i say its the clutch, joeep91 had the same problem with that noise and it was the center of the clutch had broken up and was rattleing like mad! Quote Link to post Share on other sites
jim808 Posted August 31, 2009 Author Share Posted August 31, 2009 thanks lads looks like its back to stripin the gearbox once again i'll keep yous postedMuch appreciated Jimbob Quote Link to post Share on other sites
Glanza_Ragger Posted September 1, 2009 Share Posted September 1, 2009 Ahh yeah i read that as you replaced the clutch too my badCould well be a spring thats shot, that would make a racket Quote Link to post Share on other sites
jim808 Posted September 8, 2009 Author Share Posted September 8, 2009 Glanza_Ragger said: Normally, when theres a grinding / whirring noise with the clutch up, it means the thrust release bearings running dry and had it.thats usually why the noise goes away when you put the clutch down.If you follow my guide on how to replace a clutch , its in the how to section , then you should be fine.id assume the thrust bearings being a prick. did you grease it up? and check the release fork isnt damaged?Come to think of it i didn't actually grease up the bearing could that be it ???? Quote Link to post Share on other sites
