ToyotaTech15 Posted September 15, 2009 Posted September 15, 2009 Hi folks,Just come off the phone with my brother and we are having a little trouble with mapping his fiesta ecu.He has a OMEX ecu and its a 1600 zetec se with ITB'S,OMEX have sent him a base map to get the car running and then it has to be mapped from there,Its all done through a pc or laptop with a cable into the ecu, which i think the EMB has aswell.The file that OMEX sent him is a CAL file?? which i dont no what that means. It also wont open it in any program i have on my laptop,Has anyone heard of these before?Any help or ideas?CheersGary Quote
Bildo Posted September 15, 2009 Posted September 15, 2009 Seems to be associated to Calender files.See below for more information mate:http://filext.com/file-extension/CAL Quote
EN V Posted September 15, 2009 Posted September 15, 2009 if your using vista it should look for a programme to open the file on the interweb Quote
starbogt Posted September 15, 2009 Posted September 15, 2009 yeah all I can find abut them is to try opening with sometype of paint or photoshop Application! could you not just ask omex? Quote
Asad Posted September 15, 2009 Posted September 15, 2009 http://www.omextechnology.co.uk/Ecus/ecudownloads.htmDownload the omex softwear and click file>open (open the CAL file) see if that helps......click map3000 plug in the ECU connection and open the cal file (stands for calibration i think looking at the drop down menu) Quote
ToyotaTech15 Posted September 15, 2009 Author Posted September 15, 2009 Cheers people,That link that you gave me Asad, when i have downloaded it which program should i open it with , as it doesnt worth with Adobe reader, or any other programs i have.Gary Quote
rorenapier Posted September 15, 2009 Posted September 15, 2009 Gary,Bear with me here, ive just figured it out!You will have to down load the latest free "winzip" software. This should open up once installed.Once that is done, open the above folder that you have already down loaded (The link Asad has provided) in Winzip.In win zip "right click" on the extract key at the top, this will then throw a window up asking where you want to put it ie: Documents etc etc.Press "ok".Once that is done, open the OMEX folder from where you have saved it above, and run the "setup.exe" icon.From here on in, it should work outno problem.Only thing is, i cant test it as i dont have a map on the comp.Hopefully this helps you out buddyRory Quote
Asad Posted September 15, 2009 Posted September 15, 2009 You dont need winzip, windows has an option to extract the files to another location (look at the top) Hes sorted it now.....just needs to transfer it onto his workshop PC and test it out let us know how you get on mate Quote
ToyotaTech15 Posted September 16, 2009 Author Posted September 16, 2009 Cheers everyone,Got it sorted now, as Asad says just need to transfer it to the computer in the workshop as my laptop doesn't have a port to plug into the ecu leadI'll let you know how it goesGary Quote
