Guys & gals,
how would you or did you hook up a 3 or 4 point harness, which mounting points would/did you use? esp the rear mounting points.
pics would be super :thumbsup:
thanks,
Kevin
I've got 3 point harneses in the gtt.
the rear i put in to the point were the middle seatbelt is bolted down.. (plug and belt.)
you get longer bolts with the harnesses so you keep your middle seatbelt aswell.. :thumbsup:
and the 2 others just bolt to were the buckle and lapbelt are on either side of the seat
hope this is of help..
thanks, yeha it certainly helps,
the point where the middle seatbelt is bolted on is not directly behind the seats, but thats not a problem then.
Somebody got some pics ?
