Squeak-Glanza Posted October 2, 2009 Posted October 2, 2009 I hope some one can help me...Recently i have started to noticed a slight nocking noise when sitting still with clutch out, but when the clutch is in it stops. When you rev it the noise picks up just a wee bit too. I also notice a wee noise when driving, i have had a listen at the gearbox and it seems to be coming from the side were the gears are, could it be some bearing or that...If someone can help or point me in the right direction that would be great thanks.Squeak Quote
ToyotaTech15 Posted October 2, 2009 Posted October 2, 2009 I'm thinking without hearing it, it could be a worn release bearing.A bearing in the box would whine when driving and not really make any noises when sitting still.Release bearing would be an easier Option than a gearbox overhaulGary Quote
RobSR Posted October 2, 2009 Posted October 2, 2009 If it makes a noise on idle then goes away when depressed hopefully for your sake it'll just be the release bearing, but you also get those symptoms when the centre section of the clutch cracks/collapses/chucks a spring out etc Quote
Squeak-Glanza Posted October 2, 2009 Author Posted October 2, 2009 I was hoping it could be a release bearing, ill just have to take it out and see...thanks Quote
Squeak-Glanza Posted October 6, 2009 Author Posted October 6, 2009 Do you know were i can get a new Release bearing...cheers Quote
ToyotaTech15 Posted October 6, 2009 Posted October 6, 2009 Toyota main dealer,Shouldn't be to priceyGary Quote
