Turbo Oil Feed/return/relocator
If you need an oil feed/return for the turbo.. You'll need the fte oil filter housing.. And then tap the block to take the bolts. Aswell as the fte sump with the return fitting on.. Or you can modify a fitting onto the fe sump :thumbsup:
