got a 5 piece cage on its way to me, has anyone got or fitted one? i need to no whether to remove or cut my carpet in the front behind seats? also does it bolt to top of rear shocker mounts? any advice or pics of theres fitted mucho apreciated, thanks <_<
You can cut the carpet mate, my car has the holes left from whewre there was a cage.
As for mounting different cages mount differently any pics??
ive recently fitted a carbing 7 point cage in mine the easy way to fit it is to mount the roll cage where you want in then drill straight throught the roll cage holes and through the carpet and floor once you drill each hole put a bolt in the hole to stop the cage from moving and drilling holes in the wrong place. just to worn you when you drill through the carpet and floor the sound deadning foat wading will get caught in the drill and you will find yourself taking most of the wading out lol the hardest part to get in is the roll over bar. good luck
You don't need to cut the carpet.. And they don't normally go to the rear struts.. The roll cage legs sit on the chassis just in front of it..
its a cusco one, i thought drilling and mounting ontop of carpet wouldnt be as sturdy? thanks for the replys guys if it dont mount on rear struts then im gutted as i missed out on a rear brace <_< lol
the cusco and carbing cages are exactly the same. and yes iy will not fit on top of the mounts they fit on the slanted parts of the arch but extend on top lightly. also i have loads of rear strut braces still attached with the cage in the carpet wont make a difference bud as you will be bplting it through the floor with plates also attached under the car
got cage in today had to remove a bit more interior plastics then i wanted too but hey ho just gota rope a mate over to help drilling and bolting <_< its a 6 leg type only probs i can see is the sun visors wont move much lol and i aint got a rear diagonal brace so may see if you can use the door type adjustables? will use a rear brace as got one coming.
got cage and got it fitted today, took about 4 hours all in most of that was gutting all the trims and gettin the bloody thing inside the car lol, the drilling and bolting was the easy bit, only bad points i can see is my sun visors are near useless now and also i gota move my larm sensors off the pillar, rest is fine so im well chuffed, combined with the front and rear arms and braces the car handles soooooooooooooooooooo nice. <_<
lucky its england and never sunny hey lol, i feela bit safer now too as driving around in a bake bean tin doesnt feel you with confidence hey <_<
lol funny you say that as its on the list of things i wana replace, i dont like it, either want a standard new type 3 spoke or a momo or sumink :thumbsup:
