actutor was workin fine on old unit. now i've gone hybrid. however much i turn actuator in it still only shows .5 on boost gauge. but i believe its on verge of fuel cut because it judders like fuel cut sumtimes. should i just turn actutor down and see what happens. if it is boostin to .8 but not showin on gauge? any ideas. its like the gauge only goes to .5 n the needle stops. although theres defiantly more pull after.
cheers craig
check the pipe that goes to the gauge. might be a leak. mine used to do this slightly but put a tiny cable tie on it and reads properly now.
