silverglanza Posted October 18, 2009 Posted October 18, 2009 hi again all lol ive odered a relocation kit but the one i had i need the silcone elbow ive ordered one whats the mm size that comes off the ct9 turbo ?any one help would be very greatful Quote
Guest Enzo Posted October 27, 2009 Posted October 27, 2009 th size i think it might be 43? 48? from memory but that might be a stab in the dark. someone else might be able to clarrify Quote
BenV Posted October 27, 2009 Posted October 27, 2009 Dude I've got one here from the toytunning kit. I've upgraded turbo now so it's of no use to meBen Quote
DavidAshton Posted October 27, 2009 Posted October 27, 2009 CT9 inlet is 39mm but you can clamp bigger sizes onto it, ive been using a 51mm elbow with no probs at all. Quote
scot-ish Posted October 27, 2009 Posted October 27, 2009 i think the ct9 inlet is 38mm, well my relocation kit is 38mm Quote
scot-ish Posted October 28, 2009 Posted October 28, 2009 ive read its 40mm now, but my kit is 38, so its gunna be acunt to get on, and aprently 40mm is hard to get on whilst the tubby is on the car, people have said 42mm gives a good fit if your fitting it with the tubby on the car Quote
silverglanza Posted October 28, 2009 Author Posted October 28, 2009 ive read its 40mm now, but my kit is 38, so its gunna be acunt to get on, and aprently 40mm is hard to get on whilst the tubby is on the car, people have said 42mm gives a good fit if your fitting it with the tubby on the cardo you have to remove the front bumper to fit? as its quite tight aint it Quote
scot-ish Posted October 28, 2009 Posted October 28, 2009 i will, because a/c is out at the same time, and the fmic is going inbut it could be done without removing the bumper pendin on the where the screw head is for the jubilee clip, could do it from underneat, and fir the relocation kit in two parts, thats assuming you can get the filter in without moving bumper out Quote
