Amjad Posted October 19, 2009 Share Posted October 19, 2009 I'm in the middle of putting Paseo clocks into my EP, but I'm stuck I'm about to swap the pins/wires that plug into the back of the speedo, but can't seem to get the metal pins out :SThese are the pins I'm on about, and yes I have removed both white plastic tab things, but still no luck! http://i9.photobucket.com/albums/a70/RRmon...et/DSC00485.jpgAny idea as to how I can get them out? I don't wanna try yanking the wire out in case it tears..there must be some sort of tab but I can't seem to find it?!Thanks,Amjad Quote Link to post Share on other sites
Sparky Posted October 19, 2009 Share Posted October 19, 2009 When I done this i used a safety pin to push down inside where the wire goes in then you give it a little tug.Should be a pic of where to stick the pin in the How 2 guide for it Quote Link to post Share on other sites
Amjad Posted October 19, 2009 Author Share Posted October 19, 2009 When I done this i used a safety pin to push down inside where the wire goes in then you give it a little tug. Should be a pic of where to stick the pin in the How 2 guide for itCheers Sparky! I've just managed to sort it out ;) you gotta poke the bit under the long metal tab then pull it outThanks for the help! Quote Link to post Share on other sites
Sparky Posted October 19, 2009 Share Posted October 19, 2009 No problem mate was one of my favourite mods in the n/a ;) Quote Link to post Share on other sites
