As enzo has mentioned in a prior post, Because the RX7 TMIC is a lot wider, The oem scoop intake (rubber square Under scoop) Doesn't quite fit the rx7 TMIC intercooler as much as I'd like. So I'm going to DIY my own to create a perfect seal ensuring maximum Cooling.
I'm sure many people have done this so was after Some ideas + pictures. Did you modify the standard rubber square, or did you remove it all together? etc =]
Thanks =]
  • 1 month later...
I think the standard black intake crap on the inside of the bonnet would need to be removed and simply extended so its wider. If the standard one was only two more inches to the right it would have been perfect. i've got a fmic now anyway but interesting to see what someone could fabricate!
