How to remove the back door trim.
Parts may be seen in link. -->CLICK
First of all whatever you do, do not try to pull the thing off, otherwise you will break the screw-fastening clips(67750A) and/or the panel's clips.
So there are 5 screw-fastening clips which have to be removed. These are a screw and a clip(looks like a washer when in place) combined together. All that needs to be done is unfasten the screw untill the whole thing starts turning, then using a screw driver gently pull out the screw part only. once the fastner starts coming out the whole clip should come out.
This has to be repeated for all 5 clips.
After all the clips have been removed gently slide the panel towards the glass of the back door. It should slide off easily.
Hope this tutorial helps. Any questions just ask
