Raz Posted October 31, 2009 Posted October 31, 2009 Yesterday to adjust my cars idle i had to remove the intercooler, i found traces of oil in there? is this normal for the glanza? i thought only air passed through:S Quote
micky boy Posted October 31, 2009 Posted October 31, 2009 Yesterday to adjust my cars idle i had to remove the intercooler, i found traces of oil in there? is this normal for the glanza? i thought only air passed through:Syes that normal mate if there is oil comeing out of your hks bov of what ever you have got then i would be concerned, a good bit of oil comeing out of the dump valve that is though Quote
B11G KY Posted November 1, 2009 Posted November 1, 2009 yes that normal mate if there is oil comeing out of your hks bov of what ever you have got then i would be concerned, a good bit of oil comeing out of the dump valve that is thoughI have a HKS Bov on ma ep91 and i have noticed the area around the Bovs opening is slightly greasy is this somthing i should be worried or concerend about? Quote
micky boy Posted November 1, 2009 Posted November 1, 2009 I have a HKS Bov on ma ep91 and i have noticed the area around the Bovs opening is slightly greasy is this somthing i should be worried or concerend about?If its spiting it everywhere mate then it,s a sine the oil seal,s are going but i dosntmean the turbo is going to pack up it could last for how every long it,s going to last for if you no what i mean lol if you start geting clouds of smok out the exhaustthen its time to change your turbo hope that make,s sence for you mate Quote
Raz Posted November 1, 2009 Author Posted November 1, 2009 oh ok, Never had to remove intercooler before so wasn't sure Quote
Raz Posted November 2, 2009 Author Posted November 2, 2009 DP sorry,I need a BETTER guide on how to by pass the solenoid to achieve better boost, i don't understand this stuff with swapping the pipes?WHAT PIPES? :S lol Quote
StarletRick Posted November 2, 2009 Posted November 2, 2009 the actuator pipes? theres only 2 of them, its not hard. it has been covered MUCH. search for it. youll find pics and everything. it takes literally 3 seconds to do. Quote
Raz Posted November 10, 2009 Author Posted November 10, 2009 it doesn't take 3 seconds, i couldn't get the pipe off the solenoid thing because it is stuck onto to it so stiff! how the hell do i take this pipe off ? shall i just rip it off and buy new ones as i was told by someone, but then its not a free mod lol Quote
Raz Posted November 11, 2009 Author Posted November 11, 2009 I DID IT!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! LOL I was just too scared to use force incase i ripped the solenoid stuff lol today i attempted it again by wiggling it after putting 100watt bulbs. AND I need to see what it does now Quote
