[ep-tune.com] Brand New Bc Racin Br Coilover Kit
BC Racing BR Coilover Kit for all Toyota Starlet and chassis related cars.
A Fairly new brand to the Toyota Starlet BC Racings BR coilover kit.
The BR series coilovers use a large 44mm diameter piston in a 53mm diameter damper body to maximise oil capacity.
some of the features of this coilover inlcude
Pillowball upper mount
Camber adjustable top mounts
Aluminium top plates
30 way adjustable damping
Adjustable spring platform
Height adjustment via bottom mount to retain full damper travel
Bearing mounted upper front spring platform
Dust boot to protect damper seals
The lower spring platform of the BC Racing coilovers are adjustable. This allows the car to be set up for corner weighting to achieve perfect balance and ensures that maximum tyre efficiency is achieved.
Optional assister springs can be purchased to allow wheel droop to be dialled into the unit to suit specific needs.
BC Racing products are TUV certified so you are safe in the knowledge that the coilovers are of the highest quality and standards. The TUV certificate is your guarantee that the BC Racing coilovers are 100% fit for purpose.
Each kit comes with everything needed to fit to your EP.
as far as im aware these are the cheapest on the market, if you see otherwise, please let me know
