ive done a 5efte swap and where the oil filter goes is slightly different. i have used my 4efte sump so i have that oil line fine. but see the little metal oil line that also connects onto the bottom of the turbo were does the other end of that go? it would normally go to the bit beside the oil filter on the 4efte but thats not there on the 5efe so what do i have to do? cheers
