Marck glanza V Posted November 12, 2009 Posted November 12, 2009 hi i was wondering if people know about different ways to lower spool time thanks marck Quote
riko666 Posted November 12, 2009 Posted November 12, 2009 Well, a turbocharger basically relies on the expansion and energy of the exhaust flow in order to operate, so improvements in this respects will serve to improve the spool characteristics; so in laymen's terms, keeping the exhaust flow reasonably hot, and by improving exhaust velocity (think kinetic energy of the exhaust flow) will improve spool.So, typical things to help spool include increasing the C/R (more air compressed, hence greater rate/volume of expansion on ignition), headwork (increase the volume and speed of air flow), uprated camshafts (greater volume, and combined with some scavenging, greater velocity), advancing the timing (cylinder mixture is more fully burned, again creating a greater rate/volume of expansion), ceramic coating the exhaust housing/manifold (keeps the exhaust hot, maintaining velocity), selecting the right wastegate and boost controller and so on Quote
Marck glanza V Posted November 12, 2009 Author Posted November 12, 2009 good info cheers so any ideas on what cams would be good and if i got cams would i need valve springs aswell. akso how would i go about advancing my timingcheers again marck Quote
micky boy Posted November 12, 2009 Posted November 12, 2009 When geting the ecu mapped im sure you can get your timeing advanced someone correct if im rong as for cams yes it would be a good idear to change the valve springs as for wonting a lower spooling time im not sure what turbo you are running but you could get a smaller turbo the biger the turbine the longer it will take to spool the biger the turbo housingand the smaller the turbine the quicker the spool lol i think im right in some why as i dont like haveing a big head incase im rong lol hope that helps anyway mate Quote
Marck glanza V Posted November 12, 2009 Author Posted November 12, 2009 When geting the ecu mapped im sure you can get your timeing advanced someone correct if im rong as for cams yes it would be a good idear to change the valve springs as for wonting a lower spooling time im not sure what turbo you are running but you could get a smaller turbo the biger the turbine the longer it will take to spool the biger the turbo housingand the smaller the turbine the quicker the spool lol i think im right in some why as i dont like haveing a big head incase im rong lol hope that helps anyway mate im running the td12 and getting full boost by 3k but want to try to lower it abitcheerd marck Quote
micky boy Posted November 12, 2009 Posted November 12, 2009 boost by 3k you dont whant much do ya lol im not so sure now lol the td12 has good spooling time so i thort and by the look of it you are geting full boost at 3k and thats mint sometimes people say if you have a big intercooler that can course a bit of lag and i noticed when i got my fmic and took the tmic off i was a bit more lagy Quote
