Newbe Posted November 18, 2009 Share Posted November 18, 2009 Might be a bit random but does anyone out there know what thread size the sump plug on a 4efte is. I only ask as im interested in getting one of these:http://www.demon-tweeks.co.uk/products/Pro...pcode=GLOFSPM14and wondered whether it would fit?Thanks for any helpMatt Quote Link to post Share on other sites
ToyotaTech15 Posted November 19, 2009 Share Posted November 19, 2009 Hi mate,I take it you will be using that plug for a oil temperature sensor as there will be no pressure at the sump plug for a oil pressure sensor, Im not sure on thread size off the top of my head, think it will either be 12 or 14,Also the thread pitch will need to be the same or it will just catch the first thread and stop.Hope this helps a littleGary Quote Link to post Share on other sites
Newbe Posted November 19, 2009 Author Share Posted November 19, 2009 Yeah was going to use it for temperature sender. Might have to just compare a starlets sump plug to someone with a ford/vauxhall see if they are the same.ThanksMatt Quote Link to post Share on other sites
WallaceGlanza Posted November 19, 2009 Share Posted November 19, 2009 It's not a good place to have a temperature sensor as it's so vulnerable, you don't want it getting ripped out by a stone then losing all your oil.... Quote Link to post Share on other sites
Newbe Posted November 19, 2009 Author Share Posted November 19, 2009 Yeah i thought about that chance of it catching on speed bumps and the like, do you know what size bolt i would need to mount the temperature sender like you have in the oil filter housing??CheersMatt Quote Link to post Share on other sites
Newbe Posted November 19, 2009 Author Share Posted November 19, 2009 Sump plug size is M12 incase anyone else wanted to know found it on TGTT (Shhh...)http://www.toyotagtturbo.com/forums/showth...=sandwich+plateMatt Quote Link to post Share on other sites
ToyotaTech15 Posted November 20, 2009 Share Posted November 20, 2009 Measured one last night m12x1.25 pitchJust incase anyone needs itGary Quote Link to post Share on other sites
Newbe Posted November 20, 2009 Author Share Posted November 20, 2009 Thanks Gary Quote Link to post Share on other sites
