i just got my armrest from idress .
does anyone know ho to split the bracket sliding piece ?
it has nuts stuck in it
any help would be apprectiated asap guys
Its on a slider..have you tried sliding it either way to see if there is any scews which hold them together?
Im not sure if thats how you do it though?
yeah am tying that now but wont shift dont wana break it lol.
slide it all the way to the front and you should find a scew on wither side that will let it slide of the back of the rail.
nope no screws??
  • 1 year later...
Bump!!
My question is how do I slide it?? Lol
There is a lever but it seems so stiff that any attempt at moving it feels like it will snap off, it even creeks as if the plastic is bending and about to snap off! ( the lever that is. )
Some just enlighten me on how to slide it.
( can't create new topic because I am on my iPod )
Yeah the lever will greek a little as it is a plastic piece that acts like a spring thing, hard to explain really lol But it will slide back off the rail, i have one and i alsways take it off when the bird is in the car as shes moves about and jump across all the time when parked to talk to mates ands nearly snaps it clean off every time haha
Hey guys sorry to hijack but instead of starting a new thread on armrests, i was fitting mine and then as i was screwing it into the chassis of the car, the bolts wont go back in? have i misthreaded the chassis hence it will need re tapping? could be annoying!
Dan
Customise the bugger ;)
My plastic bracket looks nothing like the original now (when it came it was a bit a busted) but its fitted and thats the main thing.
Don't be afraid to drill new holes or cut the plastic bracket if its needed. Just keep the armrest itself mint.
Joz
I might try putting some WD-40 and see what it does. The armrest hasn't been used for a long time. I had to make holes in the plastic trim and got screw and bolts from a bicycle with washers. I then had to make one hole in the bracket it self because it was broken slightly from one of the holes.
i took mine off.........yet to put it back on ill take some pictures of it and ive had the bracket apart to tighten the little bolts on the armrest
ok, sitting in the car as i write this. (drivers seat) The lever only goes to the right but i still can't slide the rest?
wtf
defo going to take some time out clean the car + fit the armrest tomorrow if i remember ill try and get some pics mabe a vid
