Guest Enzo Posted November 24, 2009 Share Posted November 24, 2009 hi, thats the stocks of current 3rd revsion gt specs.in response to some feedback about mild boost creep on arc top mount coolers from two members. mr tong has made a few tweeks to some pre production versions of the next model.namely a larger board out waistgate hole & larger penny.we did modify the internal wastegate hole from 28mm to 32mm. The wastegate flap/penny has also been enlargedright now there are a few on their way to customers. also in the pipeline is a variation of the gt spec utilising the 9 blade b turbine/shaft wheel which is harder to get a hold of(price reflects that) but more efficient.should help with response a bit.its called the GT spec B. I will keep you guys updated with pictures of the new GT spec B and dyno graph developments when it apears soon.there are also some more MHI based suprises coming your way so keep checking back. Quote Link to post Share on other sites
Steve GT Posted November 24, 2009 Share Posted November 24, 2009 uwwww nice little addition to the already well designed tongscant wait to save the pennies up and get a hybrid ordered lolany rough ideas of the prices of one of these 9 bladers? or is it a wait till you get more info kind of thing? Quote Link to post Share on other sites
Guest Enzo Posted November 24, 2009 Share Posted November 24, 2009 its the latter mate, . Aproxmate prices are going to be around the £525 mark when the spec b comes out soon.. Quote Link to post Share on other sites
Steve GT Posted November 24, 2009 Share Posted November 24, 2009 niiiice so what do you get for that etra price. is the 9 blader more reactive?faster spool etc? Quote Link to post Share on other sites
andy.i Posted November 24, 2009 Share Posted November 24, 2009 nice one geoil be ordering a hybrid off you in the new year, not sure what one yet Quote Link to post Share on other sites
junior_G Posted November 24, 2009 Share Posted November 24, 2009 Hey enzo,'' in response to some feedback about mild boost creep on arc top mount coolers from two members. mr tong has made a few tweeks to some pre production versions of the next model ''I thought arc tmics' could not be used with the gt spec - period ?cheersglen Quote Link to post Share on other sites
Guest Enzo Posted November 25, 2009 Share Posted November 25, 2009 @ badass, that price is including vat mate, something im having to charge now. ive been holding off for a while until i release my seperate commerce shop.also the 9 bladers are in shorter supply over at Tong hqbut im expecting marginaly better performance with the use of the extra blade to drive the compressor wheel.@ GlenI thought arc tmics' could not be used with the gt spec - period ?in the summer (july?) two members used gt specs on arc top mount intercoolers. they both reported back mild boost creap. (1-2psi)since that time i altered the add to reflect that.these new changes will cure the mild creep meaning you can fit this onto a standard starlet turbo setup with top mount. Quote Link to post Share on other sites
bucketep91 Posted November 25, 2009 Share Posted November 25, 2009 cant wait for 1 of these Quote Link to post Share on other sites
junior_G Posted November 25, 2009 Share Posted November 25, 2009 cheers enzo Quote Link to post Share on other sites
andrewvturbo Posted March 3, 2010 Share Posted March 3, 2010 anymore news on the GT SPEC B TONG TURBO?? hi, thats the stocks of current 3rd revsion gt specs.in response to some feedback about mild boost creep on arc top mount coolers from two members. mr tong has made a few tweeks to some pre production versions of the next model.namely a larger board out waistgate hole & larger penny.we did modify the internal wastegate hole from 28mm to 32mm. The wastegate flap/penny has also been enlargedright now there are a few on their way to customers. also in the pipeline is a variation of the gt spec utilising the 9 blade b turbine/shaft wheel which is harder to get a hold of(price reflects that) but more efficient.should help with response a bit.its called the GT spec B. I will keep you guys updated with pictures of the new GT spec B and dyno graph developments when it apears soon.there are also some more MHI based suprises coming your way so keep checking back. Quote Link to post Share on other sites
bucketep91 Posted March 3, 2010 Share Posted March 3, 2010 ive got 1 on my car its awsome mate;) Quote Link to post Share on other sites
Spoonz Posted March 22, 2010 Share Posted March 22, 2010 ive got one made 173bhp at 13psi Quote Link to post Share on other sites
5T4R7ET N/A Posted March 22, 2010 Share Posted March 22, 2010 ^^^ what supporting mods did you have? Quote Link to post Share on other sites
Spoonz Posted March 23, 2010 Share Posted March 23, 2010 all your basic modsoner rrfpr fcd actuator etc etc will be back at the rollers next week with more boost:) Quote Link to post Share on other sites
