silverglanza Posted November 25, 2009 Posted November 25, 2009 hi guys ive seen a post or 2 on here about will you see any perfourmance gains but they have said buy a fmic but this tmic is alot larger than standered your bound to see gains i just got one but not delivered yet and any one made there own seal cant be that hard can it ?? cheers for all the help Quote
DavidAshton Posted November 25, 2009 Posted November 25, 2009 What? I stuggle to understand that, seals? what seals? Quote
Idrees Posted November 25, 2009 Posted November 25, 2009 I think he means the seal under the bonnet that helps the air get to the cooler. Quote
Jae-Glanza Posted November 25, 2009 Posted November 25, 2009 Hmm, When i first purchased it i was searching the forum to find out as much as i could. i found a picture where someone had put some rubber strips ontop of the cooler to make a better seal.However, i wouldnt bother! once you fit it and close your bonnet, put your hand in your scoop and you'll feel that its a perfect seal anyway. So i really wouldnt bother mate! Quote
silverglanza Posted November 25, 2009 Author Posted November 25, 2009 bhp gains???? on a rx7 cooler from standered cooler Quote
micky boy Posted November 25, 2009 Posted November 25, 2009 not much it will just be able to take more bhp and with it been alloy it will disperse heat a lot fasterthan the oem plastic you might see a bit of a gine but not a big amount hope that helps Quote
