Hi guys, Just wondering if anyone on here has ever had there N/A Compression tested. If so what were your readings?
Also if anyone knows what the readings are suppose to be for a 4EFE if they could post them up that would be helpful.
Had mine tested last night and my results were,
Cylinder 1 = 205, Cylinder 2 = 205, Cylinder 3 = 205, Cylinder 4 = 206
Are these normal?
Thanks
Liam
  Gary_EP91 said:
They all seem consitant mate, if i was at work id check the manuals for you,
from memory im sure its ment to be 180 or 190 up to just over 200,
So it should be ok, dont take it for definate, ill try and get a manual from college tomorow
Gary
Yeah thats what we thought mate, there all consistant so it should be ok, if you could check for definate from your manual mate that would be helpful, so then we know for future reference!! :thumbsup:
Right got these compression readings from the Toyota 4EFE workshop manual,
All cylinders should be 185 psi (1,275 kPa, 13.0 kgf/cm2) or more, with no more than a 14 psi (98 kPa, 1.0 kgf/cm2) difference between the cylinders
Your car is more than fine Liam
Hope this helps
Gary
