chriswoodfto Posted December 1, 2009 Posted December 1, 2009 hi guys, im just looking into sorting a new bov. does anyone have a fitting guide? ive spent an hour looking and no luck, ive read info on blocking off the standard bovs pipe etc? again i have no idea which pipe or what im on about actually,lol. so any help would be massivly appreciated.cheers, chris Quote
Glanza_cl Posted December 1, 2009 Posted December 1, 2009 it's pretty simple buddy, you pull off the old one and slap on the new one lol have a look at my pic below... you will take off the original reserc, put you new bov onto the existing pipe, then you see the little silver thing that is blocking up were the original bov was?? you can just block that off with a 50p (cant remeber if thats to big, but you get the idea) by just glueing it in there.you use the same vac lines that went into the original bov, and the black breather pipe that comes out of the rocker cover... you can either leave that as it is, or buy a small breather filter and put that in it's place.Hope that helps mate Quote
chriswoodfto Posted December 1, 2009 Author Posted December 1, 2009 sound, ill wait for it turn up and hopefully itll explain its self a little bit more.lol. Quote
chriswoodfto Posted December 1, 2009 Author Posted December 1, 2009 bailey, i also need a new rubber nipple for the end of it. any ideas were id find one of them? b+q maybe? Quote
Glanza_cl Posted December 1, 2009 Posted December 1, 2009 i thought it might have been that lol... terible bovs haha!, not your fault but it seems all the people new to glanzas/gt's go for them.just be aware it might leak and possible look to spend on a slightly better variation in the future. i.e. blitz, hks, sard etc.and on the rubber nipple bit, without seeing whats missing i wouldnt be able to help, get some pics up when you get it... i'm sure someone will be able to point you in the right direction Quote
chriswoodfto Posted December 1, 2009 Author Posted December 1, 2009 http://www.ukstarletclub.com/forums/index....c=22575&hl=check out that link, its the rubber bit on the end. dont have aclue were to pick one up? to be honest mate ive bought a set of whiteline springs from a guy on here and he very kindly threw the the bov in for me. so just trying to find the oarts i need to fit it, 28mm silicon hose aswell im told??? Quote
Curtis Posted December 1, 2009 Posted December 1, 2009 i have one of them bov's and its crap, it always leaks i wouldnt even bother fitting it Quote
chriswoodfto Posted December 1, 2009 Author Posted December 1, 2009 ahh, what would you guys suggest then? just seen the hks ones and that are 250quid!!! Quote
Glanza_cl Posted December 1, 2009 Posted December 1, 2009 good second hand ones pop up all the time in the sales section, just keep an eye out.keep an eye on tgtt.com aswell.you should be able to pick up a blitz for about £60-80 used on here Quote
jeppo Posted December 1, 2009 Posted December 1, 2009 i got a bailys valve with no nipple took the valve to b&q found sum steel tubing that just slid in snug tok the valve apart mushromed the end of the pipe nd puked it thru and liquid metal to stick and seal it nd ive had no bother with it probz beter than the plastik niple on them Quote
chriswoodfto Posted December 1, 2009 Author Posted December 1, 2009 cool. will have to bide my time then, hmmm? ill see when it arrives if i can find a nipple,out of intrest does the blitz bov have to be for a glanza or will any do??? Quote
chriswoodfto Posted December 1, 2009 Author Posted December 1, 2009 blitz bov bought 60quid with all fittings needed. Quote
silverglanza Posted December 1, 2009 Posted December 1, 2009 haha i have like a 40 pound one doesnt leak and its fully ajustable loud as mate if you get in to any bother ill take a pic of mine i got a little oil breather filter on top of rocker cover looks nice Quote
Jae-Glanza Posted December 1, 2009 Posted December 1, 2009 I as new chap to turbo's went for bailey, bloody crap on the motorway. leak leak leak. just annoys me!grrr Quote
chriswoodfto Posted December 1, 2009 Author Posted December 1, 2009 whats the benefits of having a decent dump valve out of intrest? Quote
Dannymo Posted December 17, 2009 Posted December 17, 2009 I got a baily aswell im same as the guy above it leaks constantly Quote
Smithy_dub Posted December 17, 2009 Posted December 17, 2009 How do you actually adjust the Blitz BOV's? Ive messed with that screw on top but it doesnt make any difference... new spring?? Quote
chriswoodfto Posted December 17, 2009 Author Posted December 17, 2009 me too mate, i screwed it right in and out the other day and it did nothing, they sell replacement springs on ebay, up to 0.8bar. 0.8-1.2bar, 1.2 and above, depends what boost your gona run, if sticking to 0.8 id go for the up to 0.8 as i wreckon mines got the 0.8-1.2 in now and its too firm, im upping the boost soon so ill let you know if thats sorted it. Quote
Raz Posted December 18, 2009 Posted December 18, 2009 noob question here, how do you know if its leaking? is that the hissing sound when i gently press the accel down and here some hissing sound as the turbo spools up? Quote
Wantaglanz Posted December 18, 2009 Posted December 18, 2009 noob question here, how do you know if its leaking? is that the hissing sound when i gently press the accel down and here some hissing sound as the turbo spools up?Thats just the sound of the turbo? you probs have to rev it up with your head under the bonnet to hear if its leaking? ;) ;) Quote
