rmsnoel Posted January 28, 2010 Posted January 28, 2010 @ quiet-achiever could you please weight the celica calipera and discs and compare them to the starlets, I found a set in the scrappy but my god the disc was a tonne weight Quote
the quiet achiever Posted January 28, 2010 Posted January 28, 2010 @ quiet-achiever could you please weight the celica calipera and discs and compare them to the starlets, I found a set in the scrappy but my god the disc was a tonne weighthi i`m not able to do weight comparsions @this time parts haven`t all arrived @i`m out of town @the moment . as the disc is larger in dia (260mm)&thicker(22mm) as well than the puny little starlet disc (238x18mm)there will be a weight disadvantage the caliper is also bigger . it is probably not the most weight concious conversion . but if it works it is way cheaper than a performance kit off the shelf &parts can are more readily avail if you need replacements especially in my case but will post more info later lyle Quote
