hi people, my glanza is smoking heavily when i start it, the smoke is alright but once the car is warm the smoke takes all my road lol, even when i drive it ders loads of white smoke
help plz
thanks
white smoke is just condensation i think my v smokes white for a while on a cold morning until the car is warmed right up
no but my glanza smokes constantly even after 30 mins non stop, and its no condensation bcuz the smoke is thick and stays around in the air for a while
Might be burning oil or intake is messed up this happend to mine but not as bad as yours sounds. Give it a oil change i no it sounds stupid but there could be junk and clunge in there sumwere
oil burns blue if its cold outside and the car is pumping out hot gasses when hot meets cold it steams might be nothing plus I've noticed it looks worse in dark when people are behined you with lights on then it lingers
Head gasket gone matey
neva thort of that but dose it come out the exhauste i thort it came out the head where the gasket had gone hens the term blown head gasket
Nah, thats why every rover you see on the road smokes like a motherfucker and has water dripping from the exhaust lol ;p
Pretty sure its burnt through the exhaust though. =]
ah right ya learn sumthing new every day
no water leaks from the exhaust, its just got oil in there when you stick your finger in it also i took the intercooler off and had some oil in there
oil in the intercooler is normal i just think your turbo has gone, or going or valve stems
change the turbo and see if its any diffrent if not then its got to be the valve stems :p
i will do micky thats why im after one, you know the valve stems is that a big job???
cheers
cheers
Does your car have the same power when you go on high boost? If yes,then its not the Turbo.
If it rattles a bit but still pushing the same kind of power then its something internal from the engine(piston rings etc).
If the car heats up quicker than normal(the water temp gauge getting close to H),then it is the head gasket.
Hope this helps.
If your going to a garage for stem seals as i was, you'll pay big big money, better of living with it and buying a forged engine off here. Its big money to do the seals.
unless you can do it yourself or pay someone on the side, cheeky cash job for them on a weekend!
Hope this helps.
that is great help much appreciated, basically the car drives normally no misfire nothing but its gt no pull and it takes a while to warm up and doesnt overheat or nothing, but i suspect it definately is the turbo as i done a compression test and that came out fine
true say i do have my wiked mechanic who is cheap and excellent on civics, pulsars nd starlets lol, bt if it the stem seals i mite get a forgd block then
  • 3 weeks later...
its rare for valve stem oil seals to cause smoking when warm there only normally when the car is initally started.
Another to note is oil burns white if you have the cat still in place. Do you have the cat still there?
If so it might also be turbine oil seals leaking on the turbo, quite common on the ct20b
Tim
TB Developments
LOL 'clunge'
