glanzapower Posted December 4, 2009 Posted December 4, 2009 I wanted to ask what is the best oil, spark plugs and etc... to use for my glanza as i am going to change the timing belt, oil filter and give it a full service. Also any other ideas to what i can service on the car and what product to usecheers Quote
ToyotaTech15 Posted December 4, 2009 Posted December 4, 2009 I wanted to ask what is the best oil, spark plugs and etc... to use for my glanza as i am going to change the timing belt, oil filter and give it a full service. Also any other ideas to what i can service on the car and what product to usecheersHi mate,I would say genuine toyota parts would be your best bet, toyota supply a 5 litre bottle of 10w40 motor oil For gearbox oil it will be 75w90 unless its fitted with a factory/aftermarket LSD,Genuine denso spark plugs are also worth gettingAlso a genuine oil filter,Depending on how big a service you are doing there will be things like,Fuel filterCoolantTiming belt kitBrake fluidAnd inspection of distributor cap and rotor arm as they can become worn over time and often get ignored.They would be the main items unless you are looking for anything elseHope this helpsGary Quote
Dave@TM-Developments.com Posted December 4, 2009 Posted December 4, 2009 FYI Toyota do not make parts, they will be supplied by the same companies that suppy Solid and Blueprint, save your money. NGK plugs are also better and cheaperClick Quote
silverglanza Posted December 4, 2009 Posted December 4, 2009 just a quick one can i use 10 40 part synthetic ?? castrol Quote
ToyotaTech15 Posted December 4, 2009 Posted December 4, 2009 FYI Toyota do not make parts, they will be supplied by the same companies that suppy Solid and Blueprint, save your money. NGK plugs are also better and cheaperClickFor whose information?I know toyota don't make parts that's why I said supply and not makeI agree with G, and in my opinion toyota genuine parts are far superior to blueprint etc,I am just trying to get the lad the best parts for money,Also I have never had a toyota part that doesn't fit where as I've had loads of blueprint brakes etc that are wrong and don't fitGary Quote
Dave@TM-Developments.com Posted December 5, 2009 Posted December 5, 2009 All the Solid Auto parts I supply are equal to genuine Toyota and mostly made by the same manufacturers, Aisin etc Quote
Asad Posted December 5, 2009 Posted December 5, 2009 Personally, fuel filter/thermostat/seals etc from toyotaevery other part is avaliable from motor factors NGK,ADL etc etc.....headgasket kits i`d only buy from toyota or federal-mogul (payen) and belts i`d buy gates (i belive toyota themselves use these guys now?) Quote
glanzapower Posted December 5, 2009 Author Posted December 5, 2009 cheers guys much appreciated, once i slap a turbo on my glanza its going for a major service and keeping it cosy over the winter Quote
glanzapower Posted December 31, 2009 Author Posted December 31, 2009 also bcuz my cars dne abt 80,000 miles, when i open the oil cap there is oil sludge inside, so what would i do with that--- mayb engine flush Quote
chr15_7_t_ Posted December 31, 2009 Posted December 31, 2009 engine flush would be the best for that i would imagine mate Quote
micky boy Posted December 31, 2009 Posted December 31, 2009 Im not to keen on engine flush it fuck,s valve stems, if i was you mate id put cheepish oil in run it for 400miles then drop it then put some good stuf in Quote
micky boy Posted December 31, 2009 Posted December 31, 2009 There is only one thing that should go into an engine and thats oil thats what it was designed for lol all this shit about engine flush is just to get you to spend more money cause they think you are flush i thort that was funny anyway lol Quote
chr15_7_t_ Posted December 31, 2009 Posted December 31, 2009 the way my mate flushed his engine was left the sump plug off and he must of poured about 10ltrs of cheap shity oil in it then filled her up with the good stuf Quote
chr15_7_t_ Posted December 31, 2009 Posted December 31, 2009 should of mentiond that he did this after his h/g went Quote
micky boy Posted December 31, 2009 Posted December 31, 2009 ^^ years ago they used diesel but fuck puting that in my engine eather lol my old glanza i had, i think the oil had never been change in its life it looked like porage lol so i give it about three oil changes and it ended up the same colour as treacle instead of black cole lol Quote
chr15_7_t_ Posted December 31, 2009 Posted December 31, 2009 does servicing your car (oil olugs filters) help take your emisions down before an m.o.t? Quote
micky boy Posted December 31, 2009 Posted December 31, 2009 im not sure about that mate if you have got a fuel pressure regulator on turn it up a bit befor it gos for an m.o.t Quote
glanzapower Posted January 6, 2010 Author Posted January 6, 2010 Would this 5-40 oil be fine:http://www.ukstarletclub.com/forums/index....showtopic=25766let me knw cheers Quote
