I am after a rebuild kit containing circlips etc. i also need 3rd gear sproket and syncro ring and 4th syncro ring, 4x shaft bearings and release bearing .Anyone know if you can get these seperate and is it a trip to toyota with your trousers down??
You can get everything seperate from toyota, obv the gears which are fixed to the shaft will require a whole new shaft if they are damaged,
Also snap rings and circlips, will need to be measure if replacing as there are about 8 choices of snap rings for the box.
I could get you a price on parts but as they are so small and there are so many of them a trip to toyota yourself would be the best option,
If you confirm parts and give me part numbers i can get discounted prices but its maybe not worth the hassle.
Hope this helps
Gary
