Blair Posted December 6, 2009 Posted December 6, 2009 may be wrong place to post...raising the limit to 8K in a V...possible at all??pointless or notforged or not??cheers Quote
StarletRick Posted December 7, 2009 Posted December 7, 2009 on a stock turbo, its pointless. they run out of puff at about 6. it is however possible, but id recomment getting stiffer valve springs first. i had my old one at 9k on the dyno, and used to rev it out to 8500 almost every time i drove it. Quote
Guest Enzo Posted December 7, 2009 Posted December 7, 2009 he has a tdo4, i would not recomend it to be honest, im pretty sure the glanza is 7400 or there abouts,after about 7500 the you start to get 'float' which requres the use of uprated valve springs as rick said, Quote
Blair Posted December 8, 2009 Author Posted December 8, 2009 thanks boys...uprated valve springs - idea for prices: parts and labour and where would do this??@Rick what set-up would you have??@Enzo...whats this float thing?? :S i'm gonna have a look see to find out more on this cheers Quote
Guest Enzo Posted December 8, 2009 Posted December 8, 2009 here is a perfect vid showing valve float. to sort it uprated valve springs from the likes of cruise is whats needed. check the forsale section they arnt cheap. Quote
ToyotaTech15 Posted December 8, 2009 Posted December 8, 2009 Thats crazy Geo, never seen it like that beforeGood vidGary Quote
Blair Posted December 8, 2009 Author Posted December 8, 2009 cheers manvid shows it spectacularly!!found some cruise ones @ £215...so you're right, not cheapoonce fitted is it just a case of having it mapped to 8/9K or do I need uprated head gasket etc??my thanks again for all the info dudes Quote
Guest Enzo Posted December 8, 2009 Posted December 8, 2009 it really would not be advised on standard internals on a tdo4 at a bar, rods have bent at 8kyou really need to lighten, balance and forge to do it properly when your talking about boost and high revs. Quote
Blair Posted December 10, 2009 Author Posted December 10, 2009 was thinking of going down that route, but wanted to know the first steps involved.superb for all the info Quote
