Guest cheshireglanza Posted December 11, 2009 Posted December 11, 2009 i started my car today and its making a noise like if the fan belt was loose but took it to garage on the way to work and they have told me that the belt is tight could it be the water pump or the turbo its not over heating and its boosting ok but when i rev the egine it gets loud any help thanks Quote
StarletRick Posted December 11, 2009 Posted December 11, 2009 does it stop?its probably just a bit of water on the belt. mine used to do it quite alot in the winter months. as soon as its warm it goes away.when turbos go, they make a real high pitch noise before making smoke bombs out of the exhaust ;] so it isnt that. water pumps mate a scratching/scraping noise. but its not really very loud when it does it. Quote
Guest cheshireglanza Posted December 11, 2009 Posted December 11, 2009 does it stop?its probably just a bit of water on the belt. mine used to do it quite alot in the winter months. as soon as its warm it goes away.when turbos go, they make a real high pitch noise before making smoke bombs out of the exhaust ;] so it isnt that. water pumps mate a scratching/scraping noise. but its not really very loud when it does it.no mate its there all the time warm and cold might try putting new belt on it Quote
ToyotaTech15 Posted December 11, 2009 Posted December 11, 2009 A trick that I sometimes use is,If the noise is still there get some silicone spray or moly grease ( not copper) and either spray or run a light film on the belt, if the noise goes away it's the belt Mines was bad for squeeling when rain was badHope it helpsGary Quote
Guest cheshireglanza Posted December 11, 2009 Posted December 11, 2009 ^^ cheers might try that tonight Quote
mizlopi Posted December 11, 2009 Posted December 11, 2009 my waterpump just went! does it sound like a rattle because i put a new cambelt on mine and it didnt sit right. Quote
Guest cheshireglanza Posted December 11, 2009 Posted December 11, 2009 ^^ its sounds like the fan belt has got wet or losse but i have had belt checked and it cant be wet cause it says in a garagr over night but when u rev it gets loud sounds like a diesal car at min Quote
Steve GT Posted December 11, 2009 Posted December 11, 2009 doesnt matter if it stays in a garage all night lol the rain wont get to it when its stood still will be puddles etcid change the alternator belt and power steering belt just to make suremine was squeeling its tits off checked it and there was a slight power steering leak which had got on the belt, changed the belt and it was finethen 2 days later a volvo hit me......but for them 2 days there was no noise Quote
Guest cheshireglanza Posted December 11, 2009 Posted December 11, 2009 ^^ mines squeeling its tits off so might change belt on it tonight and check for leaks Quote
Steve GT Posted December 11, 2009 Posted December 11, 2009 cant do any harm dudebetter safe then sorry lol Quote
Guest cheshireglanza Posted December 11, 2009 Posted December 11, 2009 dont want it to die after i hand some cash over to idrees tonight for bonnet,oil catch can,fmic Quote
