Russleh Posted December 27, 2009 Posted December 27, 2009 think its a wepr decat and it doesnt fit to my exhaust system. it is the right shape to fit on but instead of aligning with the holes from the exhaust system for example 1 hole of the decat sits between 2 holes on tyhe system if you get what i mean. dunno if its ment to fit a gt or somethin because i know the exhaust system on them is different ?? help appreciated as the one thats on is about to snap lol. Quote
Dan Evans Posted December 27, 2009 Posted December 27, 2009 hmm, either get yourself a new system to fit the decat, or new decat to fit the system.what is the shape of the flange that joins to the decat? Quote
Ryan-11 Posted December 27, 2009 Posted December 27, 2009 im sure wepr decats only fit onto wepr exhausts unless u ask them to make it fit a standard exhaust Quote
Russleh Posted December 27, 2009 Author Posted December 27, 2009 chargin some batteries for my camera the now so will makle up a little drawing to take a picture of. it does fit the exhaust and the turbo but only 1 at a time Quote
Dstillie Posted December 27, 2009 Posted December 27, 2009 what about exhaust paste could you not use that to seal it up? Quote
Russleh Posted December 27, 2009 Author Posted December 27, 2009 little drawing i made up. at first i thought ok ill just turn the middle section upsidedown but that was just a daft thought because then it wouldnt fit in the hanger bit and the backbox dont fit. picture of decat Quote
Dan Evans Posted December 27, 2009 Posted December 27, 2009 what if you unbolt the center, turn it round, n bolt it that way, it looks like it may work. Quote
Russleh Posted December 27, 2009 Author Posted December 27, 2009 i thought of that but then my backbox wouldnt fit to the mid section. annoying lol. Quote
Dan Evans Posted December 27, 2009 Posted December 27, 2009 well mine comes as a four piece system, so the center splits in two, does yours not just have a normal two bolt flange on it? Quote
Russleh Posted December 27, 2009 Author Posted December 27, 2009 got it with the sleeper when i bought it off streetracer_starlet . does that mean any other decat should fit it then ?? including the decat my system is in 3 bits with 2 triangle flanges. Quote
Dan Evans Posted December 27, 2009 Posted December 27, 2009 hmm, have a play around with the center mate it should fit. Quote
Russleh Posted December 27, 2009 Author Posted December 27, 2009 well i took one off that fitted so i dont think i should have to move the centre and i cant move the centre because it wont fit the hanger and then it wont fit the backbox either. Quote
rorenapier Posted December 27, 2009 Posted December 27, 2009 Its a WEPR decat to suit a WEPR exhaust I know this as it was mine... ;)Either get a WEPR system, which was on the sleeper, or buy a new decat to suit the standard system.Simple. Quote
Russleh Posted December 27, 2009 Author Posted December 27, 2009 im using the system of the sleeper and it doesnt fit. fitted with the one that was on there thats about to snap at the top. unless the system was changed at some point. Quote
rorenapier Posted December 27, 2009 Posted December 27, 2009 If i remember right, im sure Graeme had this problem when i sold him it.From what was figured out, the WEPR system changed slightly through the years.Find out from Graeme, im sure he will know. Quote
Russleh Posted December 27, 2009 Author Posted December 27, 2009 i text him the other day and he said it would fit so it dont matter. goin by this topic if i buy a normal decat it will fit so im not to worried i was just startin to think none would fit Quote
Dan Evans Posted December 27, 2009 Posted December 27, 2009 sell the wepr one and buy a normal one bud Quote
Russleh Posted December 27, 2009 Author Posted December 27, 2009 thats what am gonna do. dont suppose anyone has an older wepr exhaust they want a decat for hahah Quote
GTnomez Posted December 27, 2009 Posted December 27, 2009 why not go to an exhaust shop and let them cut the flange and rotate it so the holes align? Quote
andy.i Posted December 27, 2009 Posted December 27, 2009 any fabricator should be able to zip it off and weld it back on, if it were mine id do it myself at work Quote
rorenapier Posted December 27, 2009 Posted December 27, 2009 You wont be able to by any other decat for it Where the flange sits (at 90 degrees from the parrallel) will only fir with the WEPR system.You cant go and buy a Roadrunner or anything like it as it wont fit, without an extension peice being made up.As lads above have said, take it to a local fabricator and have them weld it 180degrees from where it is.Simple and will cost peanuts. Quote
Russleh Posted December 28, 2009 Author Posted December 28, 2009 nah a roadrunner will fit because i dont have a wepr system thats the problem. ill see if theres any roadrunners about because i want one to match the mani anyhoo if none come up for a while ill see about gettin that one chopped. Quote
