ive had a quick measure of the discs on my glanza S through the wheel and they seem to be approx 235 - 240 mm diameter,
i would like to change the discs and pads in the next few weeks but ideally id like to get some grooved discs. does anyone know where i can get some from as only ones i seem to be able to finde are 255mm Glanza V discs,
also does the glanza V not use the same calliper as the EP91 SR / Glanza S so can i get the 255mm discs to fit?
Jim
i can't imagine the S discs being any different to V discs mate, altho i could be wrong. most likely, the S is not specified by websites sellin discs as they are so rare, with the Vs being much more common.
As for the caliper, it appears to depend on the year of the N/a as to what calipers it had. 1998-99 N/a models came with the same calipers as the Glanzas, before that the calipers were slightly smaller.
I, for example, am running GT 3G grooved discs on my car with GT carriers and my stock calipers (mine's a 1998 so same calipers as Glanza V)
Phil.
I thought that the S brakes were the same size to the sr again i could be wrong as i have been wanting to change the brakes for a while but just didnt know which ones to get
Craig
