Scam Advert,do Not Buy,..warn Others! !
http://pistonheads.com/sales/1170816.htm
this was my friends old car,what you see in the pics is the real spec,he has also received a letter from the dvla months ago saying it had been scrapped
unles for some stupid reason they have go the wrong pics up,plus the importer was 1st owner,and my mate 2nd so i dont see why a garage would do loads of work without registering it to them and updating pics.
the fmic is a transit van one,not piped up and runnin standard tmic
says lowering springs when you can clearly see it has tien coilovers
then my mate had it it didnt have a SINGLE item on that lis installed.
STARLET GT TURBO TAX&TESTED WELL LOOK AFTERED DRIVES MINT 2 OWNERS FROM NEW LOADS OF EXTRAS!!!!!!!!!!
-Wiseco 74.5mm Low Compression Pistons
-Block Notched to allow Scat Rods then re bored and honed to correct size
-New Head Bolts
-New ACL Bearing shells and thrust washers
-Cylinder Head has been Ported, including reground valves
-New Water Pump
-New OE Oil Pump
-New Cam belt and tensioner kit
-Painted rocker cover and inlet manifold
-Custom exhaust manifold with 38mm tial external wastegate and screamer pipe
-Custom T25 hybrid turbo with enlarged comp. wheel and 360 deg. thrust bearing for extra durability
-370cc injectors
-Autobahn front mount with custom hot side pipe
-Custom bumper exit exhaust with titanium tail pipe
-Greddy E Manage blue with both harnesses and 3 bar map sensor
-Exedy 3 puk paddle clutch
-Greddy 1.5bar boost gauge
-TSW Volcano 15x7 rims with 2 new 195/45 eagle f1s and 2 good toyo t1s
-40 mm lowered spax/rsr springs
-Grooved front discs with good pads
RING FOR MORE INFO ON 07759444669 £2195 OVNO
ive reported them to pistonheads
be warned,
Aaron
Yea right, looks pretty stock to me :)
Nice one for the heads up mate
