chriswoodfto Posted January 25, 2010 Posted January 25, 2010 yea its the thiner pipe of the two, goes into the top of my blitz bov not the big fat one at the bottom, mines fooked so wana order a new one, after the diameter of the pipe not lenth. cheers. Quote
lukEp Posted January 25, 2010 Posted January 25, 2010 I got 22mm to 35 mm 90 degree and fits perfect22mm being the intercooler pipe end Quote
andy.i Posted January 25, 2010 Posted January 25, 2010 for the vaccum? (one that goes to inlet) its bout 8mm Quote
lukEp Posted January 25, 2010 Posted January 25, 2010 Sorry my fault read it wrong now sounds like vac pipe Quote
Si@Fiske Posted January 25, 2010 Posted January 25, 2010 Post in the right section eh mate!Cheers Quote
chriswoodfto Posted January 25, 2010 Author Posted January 25, 2010 Post in the right section eh mate!Cheers just saw ep91 on someone elses post, so clicked that as its a ep91. didnt realise it was members ride bit. told...thanks any ways guys, ill order some 8mm then. cheers. Quote
Michel_M Posted January 25, 2010 Posted January 25, 2010 Are you guys sure it's 8 mm? I replaced my BOV a couple of weeks ago and pretty sure the stock vacuum line is 6 mm, I also had to get a small 4 mm piece from the vacuum filter to BOV (but think that's only necessary with a SSQV). Quote
chriswoodfto Posted January 25, 2010 Author Posted January 25, 2010 ill go measure it tomorow, lol. Quote
Michel_M Posted January 25, 2010 Posted January 25, 2010 Lol, reason I still remember it is that it clearly said in the manual that both 4 and 6 mm hoses fit on one side of the vacuum filter and the stock hose fitted perfectly on the 'widest/6mm' part. But measure it, just to be sure anyway. Quote
chriswoodfto Posted January 26, 2010 Author Posted January 26, 2010 for any one in the future, the diameter of the pipe is 10mm, diameter of the hole throguht he middle is 6mm, (vac hose) Quote
