Guest cheshireglanza Posted January 27, 2010 Share Posted January 27, 2010 got my forged engine running last night with td04 turbo took the car out for quick run when i got to set off lights could see smoke coming from under the bonnet pulled over had look in engine bay loads off blue smoke coming from round bottom off turbo it boosted fine didnt over heat what could it be Quote Link to post Share on other sites
Sanchez Posted January 27, 2010 Share Posted January 27, 2010 Maybe turbo seals? is it used td04? Quote Link to post Share on other sites
Guest cheshireglanza Posted January 27, 2010 Share Posted January 27, 2010 yes it is dude i did think it might be the seals but needed other peoples help,would the seals make it smoke really bad? Quote Link to post Share on other sites
micky boy Posted January 27, 2010 Share Posted January 27, 2010 If its smoking from the bottom of the turbo it could be the gasket/or it could be cause you have just fitted the turbo and its just burning the access shit off/oil you have droped on it or something.....let it tick over for 20min or so the take it for another spin if you have lots of smoke comeing out of the exhaust when you give it big licks then i would be a bit concerned but you dont you have smoke comeing out from where the turbo is it self Quote Link to post Share on other sites
Guest cheshireglanza Posted January 27, 2010 Share Posted January 27, 2010 ^^ cheers micky boy going to give it good run tonight if its still doing it guy who sold me the turbo will be getting call Quote Link to post Share on other sites
micky boy Posted January 27, 2010 Share Posted January 27, 2010 Not a problem mate just let it warm up for a bit then take it for a spin when the boost kicks in have a look in your rear view mirror for smoke you might get a bit thats normal but if it dose it bad give that lad a call ASAP Quote Link to post Share on other sites
ToyotaTech15 Posted January 27, 2010 Share Posted January 27, 2010 Did you fit new gaskets with the turbo?They smoke quite a bit on first start upGary Quote Link to post Share on other sites
Guest cheshireglanza Posted January 27, 2010 Share Posted January 27, 2010 Did you fit new gaskets with the turbo?They smoke quite a bit on first start upGaryit starts up fine no smoke soon has engine gets warn smoke from bottom off turbo got really bad if there was leak onto hot engine but i cant see any leaks so going to get it on car lift tonight Quote Link to post Share on other sites
micky boy Posted January 27, 2010 Share Posted January 27, 2010 just let the engine burn the oil off the turbo/mani you will of had your greasy hands all over it when fiting i bet you cant wait to get home to start it up lol Quote Link to post Share on other sites
Guest cheshireglanza Posted January 27, 2010 Share Posted January 27, 2010 ^^ its at home dude shit myself taking it home to how fast it was think the breaks may need upgrading lmao Quote Link to post Share on other sites
micky boy Posted January 27, 2010 Share Posted January 27, 2010 ^ i might be puting a BLITZ k24 turbo on mine soon, that should get the little shit moveing lolLet me know how it gos soon as you get home Quote Link to post Share on other sites
Guest cheshireglanza Posted January 27, 2010 Share Posted January 27, 2010 ^^ will do mate Quote Link to post Share on other sites
micky boy Posted January 28, 2010 Share Posted January 28, 2010 I gess its ok now sex bomb Quote Link to post Share on other sites
Guest cheshireglanza Posted January 28, 2010 Share Posted January 28, 2010 I left comment in my build ya its fine now getting it mapped and the fueling sorted tues reason it was smoking was fuel has to lean and the mani was burning heat wrap off which made it smoke really bad Quote Link to post Share on other sites
micky boy Posted January 28, 2010 Share Posted January 28, 2010 Orr well thats good to no at least your turbo is ok if it is runing lean dont be giveing it big licks you will kill you engine its better to run abit rich then it keeps things cool im sure you will know that any lol Quote Link to post Share on other sites
Guest cheshireglanza Posted January 28, 2010 Share Posted January 28, 2010 ^^ ya i no dude im running it off boost till i get it sorted on tues Quote Link to post Share on other sites
