Lawsy Posted February 3, 2010 Posted February 3, 2010 Hey guys, Planning on getting an aftermarket boost gauge for the glanza shorty.Going to go for a mechanical one, i know that you need to rig it up to a vacuum line but which one?If anyone could help, maybe with pictures of which pipe to join the t-piece to etc, would be much appreciated!Any recommendations on what gauge to go for?Cheers! Quote
Jae-Glanza Posted February 3, 2010 Posted February 3, 2010 I'll be fitting mine in the next couple of days so will give you the heads up, i'm a bit unsure to what vacuum line myself though atm.Blitz/Apexi/Hks etc do good accurate gauge's but there a pain in the arse to get hold of and i don't fancy paying over £80 for a boost gauge when the £25.00 autogauge one's do the job =]I've just ordered a smoked autogauge one mate =] Quote
ep91steve Posted February 3, 2010 Posted February 3, 2010 Jae-Glanza said: I'll be fitting mine in the next couple of days so will give you the heads up, i'm a bit unsure to what vacuum line myself though atm.Blitz/Apexi/Hks etc do good accurate gauge's but there a pain in the arse to get hold of and i don't fancy paying over £80 for a boost gauge when the £25.00 autogauge one's do the job =]I've just ordered a smoked autogauge one mate =] wrong about price of apexi ones... Iirc 30 pound on ebay for somereason Quote
micky boy Posted February 3, 2010 Posted February 3, 2010 order one of theys mate it gives you a spot on reading http://www.rhdjapan.com/zep-racing-4mm-ext...ep82-ep91-15331 Quote
Jae-Glanza Posted February 3, 2010 Posted February 3, 2010 They'll be fakes mate, Plenty of fakes knocking about =] Quote
ep91steve Posted February 3, 2010 Posted February 3, 2010 they must sell fake apexi turbo timer to then Quote
Jae-Glanza Posted February 3, 2010 Posted February 3, 2010 ep91steve said: they must sell fake apexi turbo timer to thenWhy would APEXI do this gauge for £30.00 odd quid FROM CHINAhttp://cgi.ebay.co.uk/APEXI-AUTO-BOOST-GAU...0#ht_2828wt_939and then this 1? £125,00http://cgi.ebay.co.uk/Meter-Gauge-APEXi-BO...#ht_1638wt_1165If that top one's real, i'll eat my glanza. Arsey tit. Quote
ep91steve Posted February 3, 2010 Posted February 3, 2010 Jae-Glanza said: Why would APEXI do this gauge for £30.00 odd quid FROM CHINAhttp://cgi.ebay.co.uk/APEXI-AUTO-BOOST-GAU...0#ht_2828wt_939and then this 1? £125,00http://cgi.ebay.co.uk/Meter-Gauge-APEXi-BO...#ht_1638wt_1165If that top one's real, i'll eat my glanza. Arsey tit. arsey tit what that ment to mean? Quote
Lawsy Posted February 3, 2010 Author Posted February 3, 2010 micky boy said: order one of theys mate it gives you a spot on reading http://www.rhdjapan.com/zep-racing-4mm-ext...ep82-ep91-15331Cheers micky boy, take it you got one of these on yours then?Is just as simple as that, tap a hole anywhere in the inlet manifold and connect the vacuum pipe to the nipple? Quote
Pandamonium Posted February 3, 2010 Posted February 3, 2010 Here you go:http://www.ukstarletclub.com/forums/index.php?showtopic=2592Mark Quote
Lawsy Posted February 3, 2010 Author Posted February 3, 2010 Jae-Glanza said: I'll be fitting mine in the next couple of days so will give you the heads up, i'm a bit unsure to what vacuum line myself though atm.Blitz/Apexi/Hks etc do good accurate gauge's but there a pain in the arse to get hold of and i don't fancy paying over £80 for a boost gauge when the £25.00 autogauge one's do the job =]I've just ordered a smoked autogauge one mate =]Ok thanks mate, yeh if you could let me know how you get on, the would be ideal. Quote
Lawsy Posted February 3, 2010 Author Posted February 3, 2010 Pandamonium said: Here you go:http://www.ukstarletclub.com/forums/index.php?showtopic=2592MarkThanks Mark, thats quality! Just out of interest where does that hose come from and go to, i would have a look but pitch dark outside! Quote
Pandamonium Posted February 3, 2010 Posted February 3, 2010 I havent looked at it close enough to know sorry, I just know its the one closest to the engine itself and is a boost pipe lolMark Quote
Lawsy Posted February 3, 2010 Author Posted February 3, 2010 Pandamonium said: I havent looked at it close enough to know sorry, I just know its the one closest to the engine itself and is a boost pipe lolMarklol ok no worries, thanks for your help mate Quote
micky boy Posted February 4, 2010 Posted February 4, 2010 Lawsy said: Cheers micky boy, take it you got one of these on yours then?Is just as simple as that, tap a hole anywhere in the inlet manifold and connect the vacuum pipe to the nipple?Yeh mate I've got one and it gives me a spot on reading Quote
B11G KY Posted February 4, 2010 Posted February 4, 2010 What about Doing it with a T Piece? like Glanza clhttp://www.ukstarletclub.com/forums/index....ing+Boost+GAUGE Quote
Lawsy Posted February 5, 2010 Author Posted February 5, 2010 Kyran said: What about Doing it with a T Piece? like Glanza clhttp://www.ukstarletclub.com/forums/index....ing+Boost+GAUGEcheers mate, was wondering about putting a t-piece into that hose, thanks for the reasurance! Quote
B11G KY Posted February 5, 2010 Posted February 5, 2010 No probs pal i mean thats what im going to do when i get around to it Quote
chriswoodfto Posted February 5, 2010 Posted February 5, 2010 mines in with the t peice, looks dead easy that way, cut hose, bang it in, feed it into the car, if you zoom that image, look right in the centre of the image, then look right at the very top just under the strut, u can see the little white T section. just there mate. Quote
Lawsy Posted February 5, 2010 Author Posted February 5, 2010 chriswoodfto said: mines in with the t peice, looks dead easy that way, cut hose, bang it in, feed it into the car, if you zoom that image, look right in the centre of the image, then look right at the very top just under the strut, u can see the little white T section. just there mate.Oh ok cheers mate, do you know where that hose comes from and goes to? Quote
chriswoodfto Posted February 5, 2010 Posted February 5, 2010 errm, without checking it out im not massivly sure, i think to the left it goes to to this little black box (cant remember the name of it) gota little orange sticker on it, other end, no idea havnt bothered to check, just cut that tube and stick your T section in, dunt really mater wer it goes. Quote
Lawsy Posted February 5, 2010 Author Posted February 5, 2010 chriswoodfto said: errm, without checking it out im not massivly sure, i think to the left it goes to to this little black box (cant remember the name of it) gota little orange sticker on it, other end, no idea havnt bothered to check, just cut that tube and stick your T section in, dunt really mater wer it goes.Lol no worries mate was just curious thats all. cheers for your help again Quote
