anup67 Posted February 5, 2010 Posted February 5, 2010 i finally got off my arse to get tyres for my rims, and just in case i decided to measure the rim and look.....does that mean its 16" not 15" ..... hope not cause 16" tyres cost a bomb help please! Anup Quote
JAG Posted February 5, 2010 Posted February 5, 2010 I measured my old standard glanza wheels n lip to lip they came to about 15 inches despite being 14 inch wheelsSo im prety sure u just need 15 inch tires mateBut if u check on the back of the rim etc and you should find a size stamped on there Quote
anup67 Posted February 6, 2010 Author Posted February 6, 2010 theres loads of numbers on the back of mine :S Quote
starlet666 Posted February 6, 2010 Posted February 6, 2010 take a photo of the markings in the back of itit will have 15 x 6jj or 16 x 6jj or something..... Quote
anup67 Posted February 8, 2010 Author Posted February 8, 2010 take a photo of the markings in the back of itit will have 15 x 6jj or 16 x 6jj or something.....cant find something like that i just want to make sure before i buy the wrong tyres Quote
Amjad Posted February 9, 2010 Posted February 9, 2010 Maybe take it to a tyre place so they can recommend the right size? Quote
anup67 Posted February 9, 2010 Author Posted February 9, 2010 Maybe take it to a tyre place so they can recommend the right size?yh ill do that mate....thanksAnup Quote
Idrees Posted February 10, 2010 Posted February 10, 2010 They are 15" wheels Anup. This is the way it works.Obviously you are measuring the wheel from lip to lip, but the hole in the tyre is not this size. Obviously it has a wall around it, which goes at the back of the wheel to seal it etc. The hole is 15" therefore being a 15" tyre, and where your wheel will meet this hole is also 15" - on the inner side of the wheel on the actual dish, not the lip.Hope that clears things up for you mate. Quote
anup67 Posted February 10, 2010 Author Posted February 10, 2010 They are 15" wheels Anup. This is the way it works.Obviously you are measuring the wheel from lip to lip, but the hole in the tyre is not this size. Obviously it has a wall around it, which goes at the back of the wheel to seal it etc. The hole is 15" therefore being a 15" tyre, and where your wheel will meet this hole is also 15" - on the inner side of the wheel on the actual dish, not the lip.Hope that clears things up for you mate.thanks mate :surrender: helped alot Anup Quote
