shanksportif Posted September 16, 2006 Posted September 16, 2006 Hey, does anyone know if the power steering lot from a glanza work in an n/a? Cheers Quote
shanksportif Posted September 17, 2006 Author Posted September 17, 2006 Anyone? I ask because someone is breaking a glanza so it would be easy to get all the stuff needed. Just not sure if it will work in an n/a?? Quote
Starlet Nath Posted September 17, 2006 Posted September 17, 2006 Anyone? I ask because someone is breaking a glanza so it would be easy to get all the stuff needed. Just not sure if it will work in an n/a??Can't see why they wouldn't, the N/A and Glanza power steering racks look identical. I can't say I noticed any differences.You'll need the rack, all the hydraulic pipework and fittings, the reservoir and of course the pump and associated bracketry.Not sure whether the pulley will be on your engine though???Oh and you'll need a power steering belt ;) Quote
shanksportif Posted September 17, 2006 Author Posted September 17, 2006 the pulley on my engine? I'm not sure what this means? lol, but do you think it is going to be a problem? Quote
Glanza_Ragger Posted September 17, 2006 Posted September 17, 2006 as long as you get all the pipework, brackets, powersteering pump and belt etc then not a problem matey. Quote
shanksportif Posted September 17, 2006 Author Posted September 17, 2006 Are you sure about this? And would it be a big job to fit? Cheers Quote
Glanza_Ragger Posted September 17, 2006 Posted September 17, 2006 as long as your rack is the same, it wont be hard..youll have to ask someone who has had there rack out, or done a conversion to be totally sure mate. cant you get the WHOLE lot from the car being broke ? then you can make sure itll all fit Quote
