DavidAshton Posted February 8, 2010 Posted February 8, 2010 As title,I fancy my car shutting the fuck up for a change so was thinking of getting a recirc valve.Only thing is where could i recirc it to with no efi pipe.Ive got front mounted air filter, i could plumb it to that, but im guessing ill still hear it back through the filter. Like you can hear the standard recirc if you put an air filter on efi pipe.Any ideas, is it possible in anyway at all? Quote
micky boy Posted February 8, 2010 Posted February 8, 2010 The 90degree alloy pipe on the front mount filter why dont you get a flange made up so you can put the standard recirc back on Quote
DavidAshton Posted February 8, 2010 Author Posted February 8, 2010 No way ill be going vtech lol, just all the noises, bangs and rattles and wooshes and chatters are doing my nut in.I have a feeling if i link it up to the front mount air filter i will still hear it dump, with it being so close to the air filter. You can hear the standard recirc dump if you put an air filter on the efi pipe. I may just go back to stock intake / recirc set up if i can find an alternative. Quote
