Scott-EP Posted February 13, 2010 Posted February 13, 2010 Thought i would do a hows to on Replacing the Bulb that Illuminates the Heater control's, Sorry if it is abit of a vague Hows to but i initially did not intend to take picture's to do a hows to, It's simple enough to do anyway but thought it would helpI'm not the best at explaining things but will do my best Tools Required x1 Phillips screw driverx1 Flat Head screw driverParts RequiredA replacement bulb, I got one from a local Motor Factor's for 87p How toRight first off you just need to pull the little rubber bits of the end of the Heat and air flow levers (excuse the rubber gloves )Then get your Flat head screw driver and gently prise the Heater control unit out of its position and disconnect the connectionThen turn the unit over so you can see the back, You will be able to see a little access area in the plastic covering the Circuit board (I removed the plastic cover to make it easy getting hold of the bulb but you don't have to) Just use your Phillips screw drive to unscrew it about 1/4 of a turnThen here is the little bulb There is a little green sock over the top of the Standard bulb which pulls of so you can push it over the new bulbThen just re-fit the new bulb and work backwards to replace the heater control unit
