Dan Evans Posted February 13, 2010 Posted February 13, 2010 just want to know what this consists of?, if anyone has a list let me know, cheers Quote
Scott-EP Posted February 13, 2010 Posted February 13, 2010 Generally engine gasket kits consist of Head gasket, Rocker cover gasket, Inlet manifold Gasket, Exhaust Manifold gasket, Sump gasket Quote
Dan Evans Posted February 14, 2010 Author Posted February 14, 2010 yeah thought it was that one.Im after the unusual gaskets like the oil filter housing, etc Quote
ToyotaTech15 Posted February 14, 2010 Posted February 14, 2010 If you get a full engine gasket set from toyota it will come with every single little gasket on the engine from headgasket to valve stem seals.You also get a decoke kit which is just gaskets if you were replacing the headgasket so it has all the top half gasketsGary Quote
Armand Posted February 14, 2010 Posted February 14, 2010 Where could you go to get a fill engine gasket set? Could do with them if i do a rebuild Armand Quote
thunderpants Posted February 14, 2010 Posted February 14, 2010 go to toyota and say i need a full engine gasket set they have it on their epc i think last time i checked it worked out at 150 ish iirc but i could be wrong about the price Quote
ToyotaTech15 Posted February 14, 2010 Posted February 14, 2010 Pm me for genuine gasket kits,i can get them for just over £100Gary Quote
