Raz Posted February 21, 2010 Posted February 21, 2010 Well, i got boost restriction off at the moment. But i want to have low/hi functionality aswell because with my driving the turbo will last for about 10 metres... So can someone explain to me how i will re route into the solnoid but have the ability to turn it on and off i knows its possible.Thanks Quote
DavidAshton Posted February 21, 2010 Posted February 21, 2010 No. Cant have de restrestriced 1st, 2nd and Hi / Lo together. Quote
Jae-Glanza Posted February 21, 2010 Posted February 21, 2010 I'd also like to know if its possible to turn up the boost etc and no resriction but still have use of the hi/lo button.Thanks Quote
Raz Posted February 21, 2010 Author Posted February 21, 2010 It is possible with a T peice, but just want to know which way the pipes must be connected. It's something like routing it into the solnoid or something not sure :s but it can be done Quote
micky boy Posted February 21, 2010 Posted February 21, 2010 If you are on about puting the pips back to normal then there is a link herehttp://www.ukstarletclub.com/forums/index.php?showtopic=2485if you are wanting to keep the pipes as normal and run low boost then buy a boost controller Quote
DavidAshton Posted February 21, 2010 Posted February 21, 2010 You can do it with a T piece and an aftermarket actuator but its mega pointless, Lo and Hi have about 0.1 bar difference when set up with a t piece. Quote
Raz Posted February 22, 2010 Author Posted February 22, 2010 oh right, i might aswell leave it on constant hi Quote
