what they like is it like a piggy back ecu plugs in a its mapable and who can map it? and what the going price with the
HKS FCon (Main Silver Box)
Boost Map Pressure Sensor (3 Bar Map)
Sensor Harness
Injector Harness Wiring
Starlet Glanza EP-91 Complete Plug & Play Harness
and isthat everything u need?
i have the fcon not actually using it yet as i'm still on standard boost but it cost me £175 posted about 2months ago (i've only seen these in black by the way.) mine came plug and play with 3bar map sensor but i'm after the gcc to go with it next so i can tune the fuel at certain rpm levels good bit of kit but old now. You need to map these with a wideband or exhaust temp and can do it yourself.
sounds like you have the old fcon piggyback luke, with the black box?
is this the one on ebay mate? silver?
its a piggyback ecu, so pretty much the same as an emu, sorts the timing and fueling, will need setting up properly though.
emu has more features though i think, launch control etc
there are other versions, fcon iS, fcon V, fcon V Pro etc, all are very different. some are difficult to get mapped, due to the software needed, some are easier. just depends.
what so i can use my orignal ecu and plug this in to it ? thats what a piggybank is aint it?
yes mate you keep the original aswell a piggybank is just a add on
